Alt 07.10.2009, 21:35   #1
Steinbruchsoldat
Ic water spray
Wurde hier ja schon oft drüber gesprochen, ich hab`s mir mal gebaut, und funktioniert echt geil...
Hab meine Anleitung mal aus einem anderen Forum genommen:
Water spray is a good way to keep your intercooler cool, even when it`s on top of the engine...
I used the pump for the rear window washer, because I didn`t see any possibility to fit an extra tank in the engine bay.
First you shoud consider how you want to control the spray. Mine is controlled by 3 devices at same time:
-Temp sensor and controller assembly; automatically activates at an adjustable temp;
-a push switch to control it manual
I also used a on/off switch to cut the power if water is empty, etc. To control the pump I put in a relay besides the pump.
Let`s start from the inside...
Here you can see the temp controller, and the switches from backwards:
The switches again:
Just unplug the washer hose and put on a new one on the pump. Route it to the Ic and put on nozzles. First I tried a hose where I cut small holes in. It worked well, but not good enought. I think the hose wasn`t good enought. Looked like this:
You can see the temp sensor pushed into the Ic...
Now I got nozzles from a garden supply shop, which work pretty well:
Vielleicht kann ja jemand was damit anfangen...
Tönungsfolie oder Spray dogbony Tuning 7 21.02.2008 19:03
blauer spray für motorschläuche.woher? streetfighter Tuning 33 06.02.2004 23:25
Alle Zeitangaben in WEZ +2. Es ist jetzt 13:05 Uhr.
