Alt 05.01.2011, 21:46   #1
SupraJoerg
Benutzerbild von SupraJoerg
iTrader-Bewertung: (39)
Nette Liste
mit netten Werten :-)
Custom wiring/ MoTeC Tuning by: John Reed Racing
Spec list below provided by Duane:
Rear Wheel Horsepower:
710 @ 24 psi
920 @ 32 psi
1015 @ 32 psi and 100 shot
3.0 liter / 7M-GTE inline 6.
Custom one off billet steel cams by TED
Shim-less buckets
Custom rifle drilled Titanium rods by Cunningham
OEM crank
OEM bearings
JE pistons with upgraded pins
ARZ oil line
Shimmed oil pump (after market pump)
ARP hardware throughout
ATI custom damper with trigger wheel
COP set-up (MKIV coils)
ETS custom intercooler, 30x 14 x 4
Earls oil cooler
Custom C&R Racing rad. Dual pass with 2 top feeds
XRP hoses throughout.
Tial 46 mm waste gate
Tial BOV
Turbo:
GT4202 - 75mm wheel with a 1.15 exhaust
Turbo blanket
Nitrous:
NX fogger
NX purge kit
NX blanket
NX bottle billet cage brackets
Head:
Done by progressive (Steve). Head work, os valves, springs, 3 angle valve job, shim-less buckets..
Intake:
Custom Ron R intake manifold with Q45 TB.
Exhaust:
Custom exhaust by Ron.R along with header, (all 321 SS burns material) and Burns muffler.
Fuel:
RC 1000cc injectors with an OEM tank which has been sumped. Pump is a 2345 Weldon, -8 lines to a OEM fuel rail back to a -6 return.
Drivetrain:
R154 5 speed with Tilton Triple carbon plate clutch. To help hold the power on launches is a custom moly drive shaft. The rear differential is still OEM and only have broken it once!
Suspension:
6 point cage (I took the full cage out since I drive this on the street a lot) ST sway bars, CFX traction bars, A1camber and toe arms are added and Tein HA coilovers give my car the stance.
Brakes:
AP brakes 4 pot, 13.2" rotors. Ferodo pads up front and KVR CF rear. Rear has an OEM rotor but is from KVR as well. SS brakes lines are also added.
Electronics:
MoTeC M600 unlocked
MoTeC E888
MoTeC harness
MoTeC SKM knock control
M&W Ignition
AIM dash display
Tein EDFC
Interior:
Recaro speed seats. AIM dash display is custom and has been set in the OEM cluster. Custom portal for the lap top also made for east access. Custom headliner in black and leather inserts are added to give the car a newer look/appeal.
Exterior:
I like things somewhat subtle. Custom bumper was made by me. CCW classics custom for the Supra. The paint was done 2 years ago and I had everything stripped to metal, glass pulled, everything removed. If it came off, it was replaced from Toyota. Everything from glass trim, to mud flaps, to marker, taillights, moldings etc...
Custom:
Custom one off CNC water neck
Custom CNC valve covers
Custom water and alt pulleys
Custom BIG turbo badge for front of grill
Custom brackets to accommodate the sensors
Custom cam trigger wheel and sensor brackets
Custom CNC reg bracket
Custom CNC batt gauge box
Custom and many misc parts of the car throughout, the list could go on!
Track time:
9.90@147 and got booted for no nhra license. Never raced at full power and never had got a chance to dial it in.
Features/Press:
SCC / Sport Compact Car. June 03
Japanese Performance. Jan 06
SCC / Sport Compact Car. Feb 06
SCC / Sport Compact Car. April 06
Thru The Windshield 2010
Import Tuner 2011
Alt 05.01.2011, 21:48   #2
dreas
Benutzerbild von dreas
AW: Nette Liste
Die Ps zahlen sind ja wahnsinn fürn 7 M
Alt 05.01.2011, 21:58   #3
JuSup
AW: Nette Liste
Oh auch bei facebook?
Hab ich eben auch gelesen!
www.CarTaxi.de
Angebote über die Seite oder
Auftrag@cartaxi.de
5.4l F350
3l NT Targa
2l Mushibushi Evo5
2l Mushibushi Evo6
2l Mushibushi Evo6 racecar
Ihr fahrt wie kleine Mädchen
JuSup ist offline   Mit Zitat antworten
Alt 05.01.2011, 21:59   #4
SupraJoerg
AW: Nette Liste
Jepp, ich konnte es kaum glauben aber John ist schon ne Marke.
Alt 05.01.2011, 23:18   #5
bear_
Benutzerbild von bear_
AW: Nette Liste
gibts bilder von der karre/ dem motor ?
klingt schon.... geiloooo
http://www.bear-industries.ch
Alt 05.01.2011, 23:27   #6
SupraJoerg
AW: Nette Liste
http://www.youtube.com/watch?v=F9dDP...ephens/vid.htm
Alt 06.01.2011, 00:03   #7
Supra-Fan
Benutzerbild von Supra-Fan
AW: Nette Liste
Da soll nochmal wer sagen, der 7m hält nichts aus...
Alt 06.01.2011, 07:11   #8
gaijin09
Benutzerbild von gaijin09
AW: Nette Liste
diese supra war schon am 7mpower site auch.
duen aka upgradedsupra wenn guterinnere
Laci
Alt 06.01.2011, 13:11   #9
AW: Nette Liste
Liest sich hochinteressant.
Damit sollten sich Sorgen um die Serienkurbelwelle auch erübrigt haben
Gibts auch irgendwo das Drehmoment zur Leistung bzw. die Drehzahl zur Leistung?
Wäre interessant zu wissen, da er ja Custom Nockenwellen fährt.
Heftig finde ich übrigens, dass er den Druck mit JE Kolben fährt.
Fahre die Teile ja auch, aber rein vom "in der Hand halten" machten die nen windigeren Eindruck auf mich, als die Serienkolben was das Aushalten von Druck angeht.
Für mehr Drehzahl sind die JE sicherlich weitaus besser
Woher gibts die Shim-less buckets für den Kopf? *auchwill*
Weitaus mehr als die JEs erstaunt mich allerdings, dass er die Werte mit ner Serienfuelrail geschafft hat
Getriebe ist offensichtlich bulletproof und um welten günstiger als das V160
Diff. erstaunt mich, aber gut zu wissen, dass es da wohl nicht soooo schnell die Hufe streckt
Alles in allem: super Leistung
it´s all in the tune
Alt 06.01.2011, 14:26   #10
floetenjo
AW: Nette Liste
32 PSI sind ja 2,2 Bar!!!!
Hammerheftig!
Alt 06.01.2011, 16:44   #11
stefankerth
Benutzerbild von stefankerth
AW: Nette Liste
....Woher gibts die Shim-less buckets für den Kopf? *auchwill*.....
habe ich irgendwo schon mal gefunden als ich nach nockenwellen für den supra gesucht waren sau teuer.....
*Edit*habe es gefunden :http://www.toda-racing.co.jp/en/product/cam/7mg-2.html
gab auf der 7mpower seite mal ein paar bilder und dynosheets von dem typ aber die seite scheint es nicht mehr zu gehen oder ich tippe die falsche url...
Die leistung geht aber auch nur mit dem 7m weil we ja 2jz zündspulen fährt
_
K's Technik & Tuning - Shop
Facebook Saisontreffen Gruppe
Geändert von stefankerth (06.01.2011 um 16:50 Uhr).
Alt 06.01.2011, 18:28   #12
supra-normen
ex "suprafun"
Benutzerbild von supra-normen
AW: Nette Liste
david - also das seriediff hält schon ne ganze menge aus denn ich fahre schon gut 3-4 jahre die meile damit und uch ein jahr mit slicks und da ist noch nichts hin. dafür hab ich schon ein getriebe getauscht.
je -kolben fahren schon einige in der tuningszene auch nicht suprafahrer und ob der die drin hat die man so zu kaufen bekommt weisst du auch nicht. vielelicht hat er sich welche anfertigen lassen. denke nicht jeder je kolben ist gleich je kolben.
drehzahl würde mich allerdings auch interessieren da nen gt4202 schon bissl drehzahl braucht bei nem 3l motor und 1.15 turbinen a/r
mfg normen
www.druckbuden.de
Alt 06.01.2011, 19:42   #13
gaijin09
AW: Nette Liste
hier sind noch schöne bilder von diese beast
Laci
Alt 06.01.2011, 20:36   #14
supra-normen
ex "suprafun"
AW: Nette Liste
auf dem dyno hat er bloß bis 6900U7min gedreht. also das finde ich krass. das mit dem gt4202. würde mich interessieren wie er das gemacht hat. hat sicherlich mit der abstimmung zu tun. das lässt mich hoffen da ich auch höchstens bis 6800 drehen will und mache. es geht also auch mit relativ wenig drehzahl ne menge leistung.
sein kühler und die anschlüsse zum motor gefallen mir sehr gut. steckt viel arbeit und geld drin.
www.druckbuden.de
Alt 06.01.2011, 21:09   #15
stefankerth
AW: Nette Liste
Das mit dem kühler schaut interesannt aus, ist da zu und rücklauf oben?
naja mit dem 1,15 ar er fährt halt nos, da hst schon etwas mehr abgasvolumen was den turbo schneller hochlaufen lässt,
die camgears sind ja auch recht verstellt enlass 24 kw grad nachläufig, und auslass etwas vorläufig...
_
Liste von Filmen in der eine Supra vorkommt svenska Sonstiges 31 21.01.2013 00:46
Motorinstandsetzer Liste Wachmann Sonstiges 18 06.05.2009 19:03
Keine Supra, aber dennoch nette Videozusammenstellung Amtrack Multimedia 4 10.05.2007 19:09
Schwarze Liste svenska Kritik & Anregungen 47 05.02.2006 21:24
welches teil wiegt wieviel.... hier die liste suprafan Tuning 2 21.05.2004 01:41
Alle Zeitangaben in WEZ +2. Es ist jetzt 23:37 Uhr.
