Alt 02.12.2019, 16:27   #1
Steckerbelegung im Handschuhfach B1,M1 ect
Habe dafür noch ne pdf erstellt.
Auszug:
M1 Plug
Pre89 Plug Configuration
1991 Plug Configuration
HTML Code:
pre89 1991
Pin# Pin# Function
1 1 Backup Light Switch Signal
2 2 B+ for Backup Light Switch and B+ for A/C Water Valve VSV
3 3 SPD Signal from Combination Meter
4 4 RPM Signal for Combination Meter
5 Turbo Indicator Light Signal for Combination Meter
6 6 Water Temperature Gauge B- for Combination Meter
7 7 Oil Pressure Signal for Combination Meter
8 9 "W" Signal for Check Engine Light
9 10 Water Temperature Signal for Combination Meter
10 11 Signal from Defogger Relay
8 -- Blank --
B1 Plug
pre89 1991
Pin # Pin # Function
1 1 A/C Water Valve VSV
2 B2 #17 L3 Signal ECT / ECU
3 B2 #18 L2 Signal ECT / ECU
4 B2 #19 L1 Signal ECT / ECU
5 3 FP Signal (Check Connector)
6 4 EFI Circuit Opening Relay Coil
7 5 A/T Circuit Opening Relay Coil
8 6 Fuel Pump Control Relay
9 7 Circuit Opening Relay B+
10 --Blank--
11 B2 #7 "N" Signal - A/T Indicator Switch
12 10 Neutral Start Switch
13 11 A/C Amplifier
14 B2 #6 TEMS Check Connector
15 8 NSW Switch to Cruise Control Clutch Switch (M/T)
16 9 Check Engine Light
17 14 Ignition B+
18 12 Theft Deterrent Horn Signal
19 B2 #4 Headlight Idle Up Signal
20 N/A Coil to Super Monitor Computer
21 N/A Super Monitor Computer
22 N/A Super Monitor Computer B-
Dateityp: pdf Supra MA70 Connector wiring.pdf (346,6 KB, 29x aufgerufen)
Schließmechanik Handschuhfach defekt - was tun? Amtrack Technik 6 12.08.2014 21:12
Alle Zeitangaben in WEZ +2. Es ist jetzt 02:27 Uhr.
