Alt 22.09.2003, 11:01   #1
Stärkere Ölpumpe woher was giebts?
Weiß jemand was?
Wenn ja für wieviel und woher?
Alt 22.09.2003, 12:43   #2
SupraSport
Benutzerbild von SupraSport
bei uns im Shop !
TOGA HighVolume Oil Pump !
mehr dazu:
High Volume Oil Pumps
Advantages, Myths and Fables
Most stock automobile engines are designed to operate from idle to 4500 RPM. The original volume and pressure oil pump will work fine in this type of application. But, as the demands on the engine increase, demands on the oiling system and pump increase as well.
The Oil Pump's most difficult task in to supply oil to and connecting rod bearing that is the farthest from the pump. To reach this bearing, the oil travels form three to four feet, turns numerous square corners through small holes in the crankshaft to the rod bearing. The rod bearing doesn't help matters. It is traveling in a circle which means centrifugal force is pulling the oil out of the bearing.
The size of the gears or rotors determines the amount of oil a pump can move at any given RPM. Resistance to this movement creates the pressure. If a pump is not large enough to meet the demands of the engine, there will not be any pressure. Or if the demands of the engine are increased beyond the pumps capabilities there will be a loss of oil pressure. This is where the HIGH VOLUME pumps come in; they take care of any increased demands of the engine.
Increases in the engine's oil requirements comer from higher RPM, being able to rev faster, increased bearing clearances, remote oil cooler and/or filter and any combination of these. Most HIGH VOLUME pumps also hand an increase in pressure to help get the oil out to the bearings faster.
Now that we've gone over what a HIGH VOLUME pump will do, here's a couple things it won't:
1) It will not replace a rebuild in a worn-out engine. It may increase pressure but the engine is still worn out.
2) It will not pump the oil pan dry. If a pan is pumped dry, it is because the holes that drain oil back to the pan are plugged. If the HIGH VOLUME pump is also higher pressure, there will be a slight increase in flow to the top.
High Volume pumps can be a big advantage if used when needed. If installed in an engine that does not need the additional volume, they will not create a problem. The additional flow will be re-circulated within the pump.
Gruß Christian
Preis: 299€
http://www.mkiii.de
Project 2003: Ultra 7M (500+)
Alt 22.09.2003, 16:56   #3
Ölpumpe
Das find ich so schick auch im Shop alles english.Macht doch die Threads auch in english.
Alt 22.09.2003, 17:17   #4
Willi die Deutsche Googleübersetzung
Da wirst erst schlau draus hi hi.
na glaub in ruhe das Englische durchzugehen mit streckenweise nem Wörterbuch ist logischer. (war auch ne Niete in Englisch *g)
guck selbst
ÖlcPumpe TOGA HighVolume! mehrdazu: Öl der hohen Ausgabe pumpt Vorteile, Mythen und Fables die meisten auf lagerautomobilmaschinen werden entworfen, um vom Leerlauf zu 4500 U/min zu funktionieren. Die ursprüngliche Ausgaben- und Druckölpumpe arbeitet fein in dieser Art der Anwendung. Aber, als die Nachfragen auf der Maschinenzunahme, erhöhen sich Nachfragen auf der Schmierölanlage und Pumpe außerdem. Die schwierigste Aufgabe der Ölpumpe, Öl an und Pleuelstangelager innen zu liefern, das von der Pumpe das weiteste ist. um dieses Lager zu erreichen, reist das Öl Form drei bis vier Fuß, dreht zahlreiche quadratische Ecken durch kleine Bohrungen in der Kurbelwelle zum Stangenlager. Das Stangenlager hilft nicht Angelegenheiten. Es reist in einen Kreis, dem zentrifugale Kraft der Mittel das Öl das Lager herauszieht. Die Größe von bei jeder möglicher gegebenen RPM. Resistance zu verschieben die Zahnräder oder Rotoren stellt die, Menge des Öls fest, das eine Pumpe kann zu dieser Bewegung verursacht den Druck. Wenn eine Pumpe nicht genug groß ist, die Nachfragen der Maschine zu befriedigen, gibt es keinen Druck. Oder, wenn die Nachfragen der Maschine über den Pumpenfähigkeiten hinaus erhöht werden, gibt es einen Verlust des Öldruckes. Dieses ist, wohin die Pumpen der HOHEN AUSGABE hereinkommen; sie kümmern um allen möglichen erhöhten Nachfragen der Maschine. Zunahmen des Motoröl-Anforderungscomer von höherer U/min, in der LageSEIEND zu Umdr. schneller, erhöhten Lagerabstände, Remoteölkühler und/oder Filter und jede mögliche Kombination von diesen. Die meiste HOHE AUSGABE pumpt auch Hand eine Zunahme des Drucks zu helfen, das Öl an die Lager schneller heraus zu gelangen. Nun da wir gegangenen Over haben, eine was Pumpe der HOHEN AUSGABE tut, ist hier Sachen eines Paares, die sie nicht wird: 1) ersetzt es nicht ein Wiederaufbauen in einer worn-out Maschine. Es kann Druck erhöhen, aber die Maschine wird noch heraus getragen. 2) pumpt es nicht die trockene Ölwanne. Wenn eine Wanne gepumptes trockenes ist, ist sie, weil die Bohrungen, die Öl zurück zu der Wanne ablassen, verstopft werden. Wenn die Pumpe der HOHEN AUSGABE auch höherer Druck ist, gibt es eine geringfügige Zunahme des Flusses zur Oberseite. Pumpen der hohen Ausgabe können ein grosser Vorteil sein, wenn sie verwendet werden, wenn sie benötigt werden. Wenn sie in eine Maschine angebracht werden, die nicht die zusätzliche Ausgabe benötigt, verursachen sie nicht ein Problem. Der zusätzliche Fluß wird innerhalb der Pumpe rezirkuliert.
Alt 22.09.2003, 17:19   #5
Ölpumpe
Geil also ich bestell keine,wenn die Pumpe so arbeitet wie die Überstzung aber danke fürn Versuch.
Hat was kannste nix lesen spoarste Geld.
Alt 22.09.2003, 17:40   #6
Willi schaden kanns nicht das Öl ist schneller an den Pläullagern, und du hast mehr Öldruck.
Nen Druckbegrenzer haben wir sowieso drinnen sogesehen kanns auch net zu viel Öldruck geben...
Mußt mal so sehen dauert ja ziemlich lang wenn Chris den Text komplett in Deutsch übersetzt und dann hier reintippt soviel Zeit wird er nicht haben.
Theoretisch war ja auch nur die Frage obs eine giebt und für wieviel, das hat er doch beantwortet.
Das war sozusagen der Bonus mit der Erklärung net sauer auf ihn sein.
Sonst steht in Zukunft nur noch
ja bei mir im Shop 299 Euro.
Alt 22.09.2003, 21:01   #7
Nucleon
Benutzerbild von Nucleon
iTrader-Bewertung: (33)
Die Übersetzung ist bestimmt korrekt jaja. Der Englische Originaltext ist einfach nur schlecht was Grammatik und verständlichkeit angeht...
Alt 22.09.2003, 21:42   #8
Ölpumpe
So schnell bin ich nich sauer aber im Shoip könntes doch mindest in deutsch stehen weißt jannicht mal du da bestellst.
Alt 23.09.2003, 01:03   #9
Roger330
Benutzerbild von Roger330
Also, wenn Du hier in Deutschland was verkaufen willst, solltest mal ne Deutsche Beschreibung liefern, so international sind die alten in Germany noch nicht
Alt 01.10.2003, 16:51   #10
SupraSport
Übersetzung kommt ... bei der Menge an Produkten, die wir im Shop haben kann ich leider nicht immer bei Erscheinen gleich eine mit online stellen. SupraSport Europe verkauft zZt. ca. 60-80% ins nicht deutschsprachige europäische Ausland, seht es uns also nach, wenn wir immer zuerst die englische Variante online stellen und die Übersetzung meist ein paar Tage/Wochen später folgt.
und wenn jemand zu einem bestimmten Produkt Fragen hat stehe ich ihm/ihr immer gern telefonisch zur Verfügung !
Gruß Christian
http://www.mkiii.de
Alt 01.10.2003, 20:16   #11
english beschreibung
Christian das wird aber teuer,wenn ich Fragen stelle.
Alt 01.10.2003, 20:23   #12
unique
Benutzerbild von unique
unique befindet sich auf einem aufstrebenden Ast
Original geschrieben von SupraSport
.....SupraSport Europe verkauft zZt. ca. 60-80% ins nicht deutschsprachige europäische Ausland, seht es uns also nach, wenn wir immer zuerst die englische Variante online stellen.....
Is ja kein wunder wenns keiner Lesen kann
Love is like oxigene
Rechtschreibfehler gefunden ?
- prima, darfst du behalten ^_^
unique ist offline   Mit Zitat antworten
Alle Zeitangaben in WEZ +2. Es ist jetzt 02:07 Uhr.
