Alt 02.12.2007, 23:34   #1
Breth
Benutzerbild von Breth
Apexi Neo
Kann das Apexi neo nur Fuel oder auch noch Boost???
BCP-Performance
Please check!
Alt 03.12.2007, 00:25   #2
AW: Apexi Neo
Das sagt die Apexi Homepage:
The SAFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include:
- Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
CONCEPT:
High resolution fuel control with integrated VTEC control.
CHARACTERISTICS:
Revolutionary color FED display easily customized by the user. *Not compatible with i-VTEC for controlling i-VTEC (can still be used as a fuel controller)*
Also denk ich mal, dass es nur Fuel kann.
Alt 03.12.2007, 12:26   #3
S1077
Benutzerbild von S1077
iTrader-Bewertung: (40)
AW: Apexi Neo
Nur Gemischanpassung, keine Ladedruckregelung. Das brauchst noch extra...
Alt 03.12.2007, 12:57   #4
Breth
AW: Apexi Neo
Gibts den kein Gerät, das beides vereint?
Möchte einen gescheiten BoostController, habs aber satt 100 verschiedene Computerteile im Innenraum gestapelt zu haben.....
BCP-Performance
Please check!
Alt 03.12.2007, 13:00   #5
AW: Apexi Neo
Maft Pro
Alt 03.12.2007, 13:02   #6
Breth
AW: Apexi Neo
Das ist ja ein gesamtes Steuergerät oder?
Da brauche ich ja 3 Jahre bis die Karre wieder normal läuft.....
BCP-Performance
Please check!
Alt 03.12.2007, 13:19   #7
AW: Apexi Neo
Is ein Piggyback. Hast also noch die normale ECU.
Alt 03.12.2007, 13:20   #8
Breth
AW: Apexi Neo
Erklär mir mal PiggyPack....
BCP-Performance
Please check!
Alt 03.12.2007, 13:23   #9
AW: Apexi Neo
Piggyback ist ein Zusatzgerät welches zusätzlich zur ECU installiert wird. Ähnlich wie ein HKS F-Con etc.
Heißt die stock ECU bleibt erhalten.
Alt 03.12.2007, 18:45   #10
AW: Apexi Neo
Hilft dir aber nicht viel, wenn du den LMM ersetzt - DAS wiederrum ist dann nicht so einfach einzustellen.
Alt 03.12.2007, 19:00   #11
Breth
AW: Apexi Neo
Na dann, gibts demfall noch einen Controller mehr im Innenraum.....
BCP-Performance
Please check!
Alt 03.12.2007, 19:01   #12
AW: Apexi Neo
Hä??
Mit dem Maft Pro kann man Fuel und Boost auch regeln. Und es wäre das was Breth haben wollte.
Alt 03.12.2007, 19:30   #13
AW: Apexi Neo
So isses vielleicht deutlicher
apexi afc neo zwischengaschri Tuning 13 15.11.2007 17:38
Apexi, Blitz, Greddy Anzeigen/Controller Preis UP & 24h Lieferung DieTulpe Auktionen 2 01.06.2007 14:34
Apexi Power Intake KIT Supra MK3 Matce Sammelbestellungen 11 14.02.2006 14:02
Apexi S-AFC II & Co. Flames Tuning 10 21.12.2005 13:31
Unterschiede Apexi s afc / PFC-FCON / Serie Flames Tuning 12 09.11.2005 01:47
Alle Zeitangaben in WEZ +2. Es ist jetzt 05:25 Uhr.
