Alt 12.02.2003, 18:53   #1
Goorooj
info: Rückrufe und service-bulletins für alle supra-modelle.
Bulletins for 1989 Toyota Supra L6-3.0L DOHC (7M-GE)
General Recalls
TSB Number Issue Date TSB Title SSCP01 JUN 93 Campaign - A/C Expansion Valve
Service Bulletins
TSB Number Issue Date TSB Title PG027-02 DEC 02 Steering/Suspension - Ball Joint Inspection
BO010-02 MAY 02 Child Restraint - Seat Top Strap Installation
TC003-99 MAY 99 A/T - Fluid Interchangeability
AX006-99 APR 99 Antitheft - Changes For GBS Glass Breakage System
AX005-99 APR 99 Antitheft - Programing the Remote Control
TC002-99 APR 99 Drivetrain - Revised Drive Shaft Grease
AX004-99 MAR 99 Vehicle - Towing Guide
SS003-98 DEC 98 Accessories - Rivet Nut Tool
AC002R-98 JUL 98 A/C - R-12 Air Conditioner System Retrofit.
TC003-98 JUN 98 A/T - Fluid Type T-IV Replaces Type T-II
EL002-98 APR 98 Interior - Cigarette Lighter Service
AC002-98 APR 98 A/C - R-12 Air Conditioner System Retrofit
SS002-97 SEP 97 Brakes - Booster Push Rod Gauge
PG004-97 JUL 97 Body - Replacement Certification Labels
PG005-97 JUL 97 Body - Replacement VIN Plates
AC00297 MAY 97 A/C - Evaporator Odor
TC00496 DEC 96 A/T - Serial Numbers/Identification
BO01196 DEC 96 Interior - Carpet Cleaning Precautions
AC00396 NOV 96 A/C - Alternative Refrigerants and Retrofits
SU00296R SEP 96 Wheels - Balance Adapter Kit Update
B0008-96 AUG 96 PDI - Stain on Paint From Rapgard
AC00296 MAY 96 A/C - Compressor Maintenance for Stored Vehicles
SU00296 MAR 96 Wheels - Balance Adapter Kit
BO00196 JAN 96 Windows - Wire Type Regulator Assembly Installation
ATRATB345 JAN 96 A/T - Checkball Wear
B095012 NOV 95 Seat Belts - Front and Rear Extenders
EL95004 NOV 95 Instruments - Wiper Motor Circuit Breaker Inspection
SS95-003 OCT 95 Engine - Tripod Support Bar
PA95001 SEP 95 Paint - Repairs On Polyurethane Bumper
BR95003 AUG 95 Brakes - Introduction of Shim/Fitting Kits
TC95008 AUG 95 M/T - Replacement Parts, Set Required
PG95006 JUL 95 Bolts - Standard Torque Specifications
SU95004 JUL 95 Suspension - Shock Absorber Cartridge Replacement
PG95005 JUN 95 Emissions - Control Label Order Form
AC95001 MAR 95 A/C - Refrigerant Leak Detection Service Hints
ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
PG94004 SEP 94 PDI - Checklist and Procedures
POL9412 SEP 94 Warranty - Remanufactured DST Clutch Covers
SS94003 AUG 94 Tools - Toyota Checker Applications
SS94002 AUG 94 Wiring - New Harness Repair Kit Available
BR94004 JUN 94 Brakes - Pad Kits Now Available Without Hardware
PG94002 JUN 94 Emissions - Control Labels Ordering Form
BO94006 APR 94 Seat Belts - Extension Availability.
AC94001 MAR 94 A/C - Replacement Refrigerants Damage System
BR94002 FEB 94 Brakes - Cause and Repair of Vibration and Pulsation
AC93005 OCT 93 A/C - Compressor Oil Application & Quantity
ATRATB191 OCT 93 A/T - Failsafe Modes
AU93001 SEP 93 Cellular - Equipment Installation Precautions
AX93001 JUN 93 Antitheft - Transmitter Battery Replacement
BO93006 JUN 93 Seat Belts - Extenders Availablity
PG93002 APR 93 ID - Replacement VIN Plates and Certification Labels
AC93003 MAR 93 A/C - System Service/Inspection/Diagnosis
SS93001 MAR 93 Suspension - Coil Spring Compressor Warnings
ATRATB132 SEP 92 A/T - Intermittent Electrical Problems
TC92001 FEB 92 Repair Manual Corrections - A/T Clutch Drum Clearance
BO92003 FEB 92 Seat Belts - Extender Availability.
PI91008 NOV 91 Emissions - California Emissions Information Labels
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
PI91006 SEP 91 Cooling System - Using Recycled Coolants
BO91019 SEP 91 Paint - Acid Rain Damage Prevention
BO91020 SEP 91 Paint - Acid Rain Damage Prevention and Repair
EN91007 JUN 91 Ignition - Revised Signal Generator Resistance Specs
EN91006 MAY 91 Fuel - Torque Specifications For Fuel Line
BO91005 MAR 91 Seat Belts - Extender Availability
PI91002 JAN 91 ID - VIN Plates and Certification Labels Replacing
WARR9121 JAN 91 Warranty - Daily Checklist
WARR9118 JAN 91 Warranty - Discontinuation of Radio Questionnaire
WARR9120 JAN 91 Warranty - New Toll Free Audio Exchange Number
WARR9119 JAN 91 Warranty - Obtaining Audio Exchange Units By FAX
BODY046 DEC 90 Interior - Repair Kit For Squeaks & Rattles
BRAK011 NOV 90 Brakes - Two Pad Kits Now Available
PIG035 NOV 90 Towing - Guide
IND002 NOV 90 Index to Repair Manual Corrections
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
BODY040 SEP 90 Doors - Lock Bezel Removal
STR005 SEP 90 P/S - Fluid Cooler Lines/Subassembly Modified
TRANS036 SEP 90 A/T - Torque Converter Mounting Bolt Caution
TRANS038 SEP 90 A/T - Valve Body Modifications
ENG024 AUG 90 Engine Control - New ECM, Cold Driveability/Startability
WARR9042 AUG 90 Warranty - Guidelines For 800 Number Usage
WARR9043 AUG 90 Warranty - Tools to Assist Administrators
WARR9041 JUL 90 Index For Dealer Support Materials
WARR9035 JUN 90 Warranty - Canadian VIN Verification
WARR9037 JUN 90 Warranty - Claim Procedures for Floor Mats
WARR9032060190 JUN 90 Warranty - Powertrain Components
BODY017R MAY 90 Seat Belts - Extender Availabilty
WARR9027 MAY 90 Warranty - Calrification of Powertrain Coverage
TRANS030R MAR 90 A/T - Reduced Engagement Time Lag From N to R
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
BODY025 JAN 90 Seat Belts - Shoulder Belt Auxiliary Anchor Points
WARR9012 DEC 89 A/C - Remanufactured Compressor Serial Numbers
WARR9010 DEC 89 Warranty - Flat Rate Manual Video
ATRATB8934 NOV 89 M/T - Application and Lube Chart
WARR9005 OCT 89 Warranty - History Available Over TDN System
WARR9004 OCT 89 Warranty - Radio Debits
WARR9002 OCT 89 Warranty - Flat Rate Manual Microfiche
ATRATB8930 OCT 89 A/T - Math Part II
HEAT007 SEP 89 A/C - Updated Evacuation Procedures
TRANS016 SEP 89 A/T - Torque Converter Mounting Bolt Procedure
AUDO010 SEP 89 Audio - Identifying Security Lock Condition
AU010 SEP 89 Audio - Identifying a Lockout Condition
WARR8922 SEP 89 Warranty - Critical Parts Freight Reimbursement Program
ATRATB8924 SEP 89 A/T - A140E Testing Solenoids For a Restriction
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ENG010 SEP 89 Fuel - Hard Starting/Long Cranking Time
TRANS014 AUG 89 A/T - Improved B2 Seal
AU006 AUG 89 Audio - Unit Identification Number
AUDO006 AUG 89 Audio - Unit Identification Number.
ATRATB8923 AUG 89 A/T - Math Formulas Part I
TRANS007 JUL 89 A/T - Valve Body Rubber Check Balls Modified
TRANS006 JUN 89 A/T - Transmission Oil Cooler Flushing
PGI015 JUN 89 ID - VIN Plates and Certification Labels Replacement
TRANS005 JUN 89 A/T - Check Ball Added For Smoother Shift R to N
AU003R JUN 89 Audio - Fuse Installation For Radio
AUDO003R JUN 89 Audio - Radio Fuse Installation
MEMO APR 89 Seat Belts - Warning, Automatic Safety Seat Belts
WARR8916 APR 89 Warranty - Genuine Toyota Motor Oil Available
BODY016 MAR 89 Body - Fuel Door Stuck Closed
WARR8912 MAR 89 Audio - Cassette Deck 13 Pin Adapter
WARR8913 MAR 89 Warranty - Corrections to Flat Rate Manual
BODY011 MAR 89 Interior Trim - New Sun Visor Material Eliminates Squeak
BODY010 MAR 89 PDI - Removal of SR-10 (Wax Coating) Residue
WARR8914 MAR 89 Warranty - Remanufactured Automatic Transmissions
BODY008 FEB 89 Liftback - Modified Door Stopper Prevents Rattling
WARR8910 FEB 89 Warranty - Corrections to the Flat Rate Manual
AU002 FEB 89 Audio - Panasonic Information
AUDO002 FEB 89 Audio - Panasonic's Car and Truck Information
WARR8909 FEB 89 Warranty - New Limited Warranty For Parts & Accessories
SUSP002 JAN 89 Suspension - Front/Rear Shock Absorber Rattle
AUDO001 DEC 88 Audio - No Illumination With Headlights On
BODY001 DEC 88 Interior Trim - Squeak at Lower 'A' Pillar
SST001 DEC 88 Tools - Special Service Tools
PGI001 DEC 88 Vehicle - Maintenance Schedule
PGI004 DEC 88 Vehicle - Specifications
WARR8907 DEC 88 Warranty - Activity Report, 10206 Process Cycle
PGI022 DEC 88 Ignition Lock - Key Code & Key Cutter Information
WARR8904 DEC 88 Warranty - Battery Replacement Proration Chart
WARR8905 DEC 88 Warranty - Operation Codes for Air Conditioner Claims
WARR8902 DEC 88 Warranty - Pocket Warranty Handbook
WARR8901 NOV 88 Warranty - Policy and Procedures Manual
BODY024 NOV 88 Exterior Trim - Misaligned Front License Plate Dimples
PGI021 OCT 88 Policy - Vehicle Certification Label Change
WARR8829 OCT 88 Warranty - Authorized Removal of Warranty Parts Form
WARR8828 OCT 88 Warranty - Toyota Flat Rate Manuals
WARR8827 OCT 88 Warranty - Reference Manual
BODY023 SEP 88 Interior - Wind Noise At Side Mirror
WARR8826 SEP 88 Warranty - Limited For Toyota Parts or Accessories
PNT002 SEP 88 Paint - Codes & Cross References For Refinishing
WARR8825 SEP 88 Warranty - Remanufactured A/C Compressors
BODY022 SEP 88 Locks - Rattle At Liftgate Door Lock
WARR8823 SEP 88 Warranty - A/C Compressor Diagnosis Check Sheet
PGI020 AUG 88 PDI - Checklist and Procedures
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
T8117 SEP 81 Fuel System - E.F.I. Injector Contamination
Alt 12.02.2003, 19:28   #2
Boostaholic
Bruce Allmächtig
Benutzerbild von Boostaholic
Question
Was kann ich jetzt damit bitte anfangen?
Alt 13.02.2003, 09:20   #3
Goorooj
sagt mir zum beispiel, dass im märz 89 neue, nicht mehr quietschende sonnenblenden eingebaut wurden.
erzählt mir, dass ersatzkältemittel die klima kaputtmachen können...
wenn ich das bulletin jetzt irgendwo herbekomme, dann weiss ich auch welche
im februar 89 wurde ein ( türstopper? ) modifiziert, um klappern zu vermeiden.
und so weiter. sind halt jede menge infos versteckt.
der einzige rückruf war im juni 93, wegen einem klimaventil. hätten die mal besser wegen der ZKD einen rückruf organisiert
Alt 13.02.2003, 16:45   #4
Ah ja.
Alt 25.06.2004, 19:08   #5
Ice
Ice befindet sich auf einem aufstrebenden Ast
und mit dieser Liste , sowie meiner Lady fahre ich jetzt zum Toyo-Händler und sage mach mal?
Ist da was bei, wo ich mal gucken sollte, ob an meiner Lady das schon gemacht wurde? Gelten diese Aktionen nach 15 Jahren überhaupt noch?
I believe ... in the power of american ladies
Ice ist offline   Mit Zitat antworten
Alt 25.06.2004, 21:36   #6
Dirty Elch
Benutzerbild von Dirty Elch
Hi.
An dem über 10 Jahren alten Audi meiner Eltern hat die Werkstatt einen Heizkühler der irgendwo im Armaturenbrett sitzt kostenlos getauscht, weil es da irgend wann mal ne Rückrufaktion gab. Hätte sonst um die 500 Euro gekostet.
Gruss Alex.
Alt 02.07.2004, 00:56   #7
Supra Light
Benutzerbild von Supra Light
Supra Light befindet sich auf einem aufstrebenden Ast
Na denn mal auf Jungs...!
Lasst eu're morschen Wecker endlich kostengünstig generalüberholen.
Supra Light ist offline   Mit Zitat antworten
Alt 02.07.2004, 12:17   #8
Bleifuss
Benutzerbild von Bleifuss
Es gibt zu viele unfähige Toyota-Schrauber.... ich mach mein Maschinchen lieber alleine!!
Gruss Valentino Rossi
Supra-Klinik
Alle Zeitangaben in WEZ +2. Es ist jetzt 04:09 Uhr.
