Alt 09.07.2007, 00:27   #1
Supra Light
Benutzerbild von Supra Light
Supra Light befindet sich auf einem aufstrebenden Ast
Biete: Apexi AVC-R Boost Controller
Neu, unbenutzt, original verpackt.... diesen hier: http://www.underground-racing.de/sho...oducts_id/1590
520€ inkl. Versand
Weitere Details:
Zitat von Apexi
Apex AVC-R Boost Controller
This unit from Apex provides stable boost pressure control with excellent boost response. Includes an easy to read VFD display & unparalleled list of functions. The new Digital AVC-R exceeds all other boost controllers on the market today with new parameters never available until now. Some of the impressive lists of functions includes: RPM based boost and solenoid duty cycle control, Scramble Boost, Gear Based Functions, Self Learning, 2D Map Trace Mode, Analog display, Real Time and Peak Hold data, Quick response and Stable boost control. The AVC-R allows the user to control virtually every aspect of boost control whether it is RPM based or gear based. Since many factory turbochargers lose peak boost due to inefficient factory wastegates, the RPM based duty cycle adjustment can help squeeze out the maximum stable boost possible (some physical limitations will apply). Larger turbocharger applications can benefit from maximizing low end boost response without sacrificing high end stability. Graphic Playback Modes assist the user in identifying problem points in the boost curve. Scramble Boost can be used either to increase boost or decrease boost levels for a certain period of time.
MSRP $639.00
Supra Light ist offline
HKS - Electronic Valve Controller u . Boost Controller FRM Tuning 2 26.06.2005 01:21
Apexi AVC-R Boost Controller Lolek Tuning 44 02.06.2005 22:02
Welchen Boost Controller nehmen? Amtrack Sonstiges 6 24.09.2004 22:56
Probleme Boost Controller adriano Technik 0 19.02.2004 23:13
Boost Controller =Dreamer= Technik 46 19.11.2003 10:29
Alle Zeitangaben in WEZ +2. Es ist jetzt 06:41 Uhr.
