Alt 30.03.2005, 11:23   #1
Götti
Greedy Boostcotroller
Wie stellt man sowas ein? Hat jemand ein deutsches manual (pdf)? Ist das normal das das Ventil im regelberich richtig laut schnattert? Wer Hat Erfahrung ?
Gruss Stephan
Alt 30.03.2005, 11:52   #2
Welchen von Greddy haste denn?
Alt 30.03.2005, 12:29   #3
Götti
Boost Controller
Den hab ich
The GReddy PRofec B-spec. is one of the simplest, easy to use electronic boost controllers on the market today. Available in either Black or Clear Blue cases, the B-spec uses a reliable twin-solenoid valve control motor. There are two presets labeled Lo. and Hi., as well as a Balance knob to alter the wastegate boost response. This unit also can be used with both integral/actuator or external/poppet style wastegates Good for twin and sequential turbo setups. Compatible with our Remote Switching System.
Gruss Stephan
Alt 30.03.2005, 12:35   #4
http://supra-forum.de/showthread.php?t=7624
http://www.greddy.com/tech/PROFEC_B_SPEC2.pdf
http://www.greddy.com/tech/PROFEC_A_B_HELP.pdf
Alt 30.03.2005, 13:04   #5
Götti
Boostcontroller
Dank Dir
Gruss aus der Schweiz
Greedy T88H vs. Blitz K900R MichaelS Tuning 44 04.05.2004 20:44
Alle Zeitangaben in WEZ +2. Es ist jetzt 06:17 Uhr.
