Alt 03.09.2004, 13:53   #181
eddie
Benutzerbild von eddie
eddie befindet sich auf einem aufstrebenden Ast
muah! mir läufts kalt den rücken runter. so wer daten will: wo kann ich auf einen prüfstand in oder bei berlin bei dem ich die revision nicht bezahlen muss???? 1/4 meile: kein plan, war noch nicht in luckau. ich kann nur die fahrzeuge nennen die ich bis dato platt gefahren habe!
vielleicht hilft das einigen hier, mindestens das, wenn nicht sogar mehr ist drinnen:
HorsepowerFreaks Stage 5 Kits
750-775rwhp MKIV Supra
This is the Stage Five performance package for your stock Supra twin turbo. This kit will get you to 750-775rwhp with our AEM map. This configuration made 750rwhp at a mere 24psi, and 783 at a mere 26psi of boost in our HPF Supra. This turbo will easily hold 34psi to redline if you want greater power numbers out of it.
This awesome package includes the following:
GReddy T78 turbo kit
Blitz EX Difuser downpipe for big single
Titan Complete Fuel System w/850cc injectors
GReddy EVO Exhaust
GReddy 4-row front mount intercooler
GReddy red wastegate spring
HKS 272 intake and exhaust cams
AEM EMS
FJO wide-band kit w/green LED and wide-band sensor
AEM 3.5bar map sensor
GM IAT sensor and connector
GM boost control solenoid and connector
HorsepowerFreaks/TorqueFreaks AEM map for this exact combination ($150 value)
HKS DLI ignition
HorsepowerFreaks sprung clutch kit with ACT pressure plate
Fidanza flywheel
Toyota pilot and throwout bearing / snap rings
The GReddy T78 kit is the ultimate turbo kit. It has very low lag due to the divided exhaust housing and a small 67mm wheel, but has huge power potential due to its 1.0 A/R. We've dynoed well over 800rwhp with this turbo, and it pulls very hard from 4,000rpm to redline. We feel it is the ultimate compromise between streetability and raw power potential.
The stock clutch will fail after around 400rwhp which is why we have added the HorsepowerFreaks clutch to this kit. If you already have upgraded your clutch, then contact us for kit pricing without the clutch.
The Titan fuel system is the best fuel system on the market today. It comes with complete instructions and all the parts you'll need.
The 272 cams are definitely a must. They will out-perform 264 cams on this setup.
The AEM is the ultimate. We provide this complete with all the sensors / wide-band and a HorsepowerFreaks/TorqueFreaks map for your car. You will now control everything at your fingertips. The AEM does complete fuel/timing control, boost control, 2-step, nitrous control, traction control, speed based boost control, datalogging, etc. etc. etc. This is where you find tons of lost power and spend way less time discovering what's wrong as all of the sensors report to you directly on your laptop computer.
The HorsepowerFreaks/TorqueFreaks map will make your car drive nearly perfect right from when you start it up. We have maps for all combinations and configurations of just about every car. However, for the above combination we have exact maps for these specs. This is a $150 value.
The HKS DLI is necessary to increase the spark energy of your coil packs. This will allow you to run high boost without the nagging misfire problems.
The GReddy 4-row intercooler is the largest available and it is gorgeous. The piping of the GReddy 4-row intercooler is made to bolt right up to the GReddy T78. And don't be fooled that less is better on intercooler sizing. We noted a 35rwhp gain from the 3-row to the 4-row on the setup above.
The GReddy EVO exhaust is a nice progressively larger exhaust pipe that give incredible flow rates without the loud sound of the other exhaust systems on the market today. The sound is almost stock like however, the big single adds a nice low note out of the exhaust.
naja paar teile sind besser und einiges mehr hab ich auch drinne! zusätzlich darf ich sagen, dass sean und john, zwei profis auf der aem ecu, meinen wagen auf der bahn 4 tage eingestellt haben. hoffe das hilft!
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
www.studiodeluxe-berlin.de
eddie ist offline   Mit Zitat antworten
Alt 03.09.2004, 14:03   #182
sumi88
GReddy EVO Exhaust
AEM EMS
HKS DLI ignition
Fidanza flywheel
Das ist doch kein Tuning oder ?
Das ist doch die Liste von dem TV-Koch...
...Zacherl kocht und alle machen mit.
eddie, jetzt habe ich aber richtig angst.
Hast Du nur Teile von der Stange, oder kommt
da noch was ?
Gruß sumi88
Alt 03.09.2004, 14:14   #183
sumi88
So, jetzt meine Tuningteile:
Schaltblitz von AutoMeter !!!
Gruß sumi88
Alt 03.09.2004, 14:14   #184
eddie
serviert mit handgemachter einzelanfertigungen!!!! bäh! du wirst heulen weinen deine mk3 verschrotten! tut mir leid um deinen wagen
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 14:17   #185
Talking
Was macht ihr den heute ABEND?Ich hab Zeit,muß nur noch meine Ak suchen.Oder vielleicht gibt mir meine Oma ihre M 16.Dann können wir uns schon HEUTE treffen.Hat wer was dagegen? Treffen wir uns doch HEUTE zum gemütlichen ................
Alt 03.09.2004, 14:18   #186
eddie
UND von deiner kiste lass ich mich nicht schlagen! nicht nachdem ich so viele stehen lassen habe!!
stange, mein gott....meine anzüge sind das auch, joop armani boss!! und sehen sehen an mir verdammt gut aus
schlussendlich sind sie sicher, detested und erfüllen den zweck mehr als ausreichend. damit sollte dir klar werden: dein wagen ist keine konkurenz für mk4!! von eddie, klar!? deutlich kann ich nicht werden.
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 14:27   #187
sumi88
Also für Joop, Armani und Boss habe ich keine Kohle.
Ich Stecke alles in meine Kiste rein.
Piselingen kaufe ich wenn überhaupt bei C & A,
oder leih mir nen alten Kittel von Toyota aus.
Gruß sumi88
PS: 1 x Bild
Geändert von sumi88 (03.09.2004 um 14:36 Uhr).
Alt 03.09.2004, 15:07   #188
eddie
andi heute geht klar!
überlege gerade noch ob ich bei sami benzin holen soll! oder ob ich mit kindereinstellung fahre...
habe ab 20.00 feierabend!
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 15:46   #189
Zitat von Supra Light
Hmm. Sehr mysteriös, die Sache...
Dito
Alt 03.09.2004, 15:54   #190
Zitat von Andi
Ich fahr die 1/4 in 9.01/9.1/9.3/9.6/9.9(wenn ich selber schalte).Aber Eddi ist deutlich langsamer.
sicher, dass du das nicht gerade mit der 1/8 meile verwechselst?
Alt 03.09.2004, 19:50   #191
eddie
ZITAT:
You will win the 100-250km/h race, but the 0-400m will depend entirely on driver skill J When are you racing?
Sean McElderry
TorqueFreaks Inc.
http://www.torquefreaks.com (Service)
http://www.horsepowerfreaks.com (Parts)
Testimonials: http://www.torquefreaks.com/testimonials.html
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 19:50   #192
IronEagle
IronEagle befindet sich auf einem aufstrebenden Ast
Ich find die Diskussion hier ja echt mal luschtich.
Ich drück auf jeden Fall Sumi die Daumen. Und selbst wenn er nich gewinnen sollte, sollte man immer beachten das ne MK IV technisch wesentlich aktueller is und auch scheinbar, jedenfalls was die thermik angeht robuster.
Und wenn ich mir so die Äusserrungen von den Berlinern anseh muss ich mir annen Kopp packen. Teilweise seit ihr genauso niveauvoll wie die VW fahrenden Spinner in Berlin die immer die Welle machen wollen wenn ich mit meinem GSi gemütlich durch Berlin cruise. Was soll der scheiß. Sumi hat ne Wette vorgeschlagen. Macht das klar, fahrt das Rennen und dann wird sich ja zeigen das Sumi die bessere Maschine hat
Stefan
Rettet die Fische...esst mehr Steaks
IronEagle ist offline   Mit Zitat antworten
Alt 03.09.2004, 19:53   #193
eddie
@ iron igel: xyxyxy* ze!!!! gefällts nich musst auch nicht lesen. wir brauchen das, um uns gegenseitig scharf zu machen. du verstehst das nicht also RUHE! sonst ziehen wir dir das tütü an! und **************** dir die beine!
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 19:55   #194
eddie
vor allem solltest du die xxyxyx* halten wenn du keien plan hast und nen opel fahrst!
alter immer schön arschbacken zusammenkneifen!
3,5 Titan Stoker
GT47/88R
_______________
gesponsert by
www.fotodeluxe24.de
Alt 03.09.2004, 21:36   #195
supra.
supra
Benutzerbild von supra.
@iron igel
die Berliner sind halt so ...
und Sumi ist ja auch ein Berliner - hat er jedenfalls schonmal gesagt
Alle Zeitangaben in WEZ +2. Es ist jetzt 09:13 Uhr.
